ph_regactivex PowerHome formula function
Registers the activex controls (as the current PowerHome user) that are listed in the activex table.
ph_regactivex ( )
Integer. Returns a 0.
Use this function to register the activex controls listed in the PowerHome activex table. This table default contains all the activex controls that are default used by PowerHome. This function is useful to allow PowerHome to run properly as a service. This function performs the same action as the menu option File|Register ActiveX.
