ph_regexdiff2 PowerHome formula function
Searches a string of data and returns the
data between two regular expression searches.
ph_regexdiff2 ( pat1, pat2, data, start, occ,
flags, localstart, locallength )
| pat1 |
String. The starting regular expression search
pattern. |
| pat2 |
String. The ending regular expression search
pattern. |
| data |
String. The string in which to perform the
search. |
| start |
Long. The position within the data in which to
start the search. Use 1 to start at the beginning. |
| occ |
Integer. The matching occurrence number to be
returned. Use 1 to return the first matching occurrence. A 3 will return
the third matching occurrence, etc. |
| flags |
Integer
. Flags that control how the search is performed. Set
this value to 1 in order to match case. Use 0 for case insensitive
searches. |
| localstart |
Integer. The index of a local variable in which
to have the start (1st character) of
the found data returned. Use 0 to not have the start returned. |
| locallength |
Integer.
The index of a local variable in which to have the length of thefound data
returned. Use 0 to not have the length returned. |
String. Returns the data string between the
pat1 regular expression and pat2 regular expression.
This function is nearly identical to the
ph_regexdiff1 function except it uses the regular expression engine in the
Microsoft VBScript library vs the Scintilla editor regular expression engine
used by the ph_regexdiff1 function.
ph_regexdiff2("<span>","</span>",ph_readfile("c:\powerhome\weather.txt"),4,0,0,0)
The
above example will return the text that appears between the 4th occurence of
span tags in the c:\powerhome\weather.txt
file.
