ph_replaceallmulti PowerHome formula function
Searchs and replaces text within a string of data.
ph_replaceallmulti ( input, search, replace )
input
String. The data to be searched and replaced.
search
String. A ~255 separated list of searches.
replace
String. A ~255 separated list of replaces.
Returns the input string after all replacements have been completed.
Use this function to search and replace all occurences of data. You can search and replace multiple different searches by separating them with the PowerHome escape character ~255. If you have fewer replaces than you have searches, then the last replace will be used for the remaining searches.
