ph_retrievevars PowerHome formula function
Retrieves and/or deletes a copy of variables
that were previously stored in the database using the ph_storevars
function.
ph_retrievevars ( id, type
| id |
Long. The ID number you originally used in the ph_storevars
function to store a copy of the variables. |
type
Integer. The type of retrieval.
Use 0 to retrieve the stored variables into the current variable set
and delete the stored variables from the database. Use 1 to retrieve the
stored variables into the current variable set but do not delete them from
the database (they can be retrieved again). Use 2 to delete the stored
variable set without copying to the current
variable set.
Integer. The result of the retrieve
variables operation. 0 is returned for success or a type value out of range. 1
is returned if there is an error retrieving the variables with the specified ID.
2 is returned if there is an error deleting the stored variables in
the database.
Use this function combined with the
ph_storevars function to store and later retrieve a snapshot of the current
variable set.
ph_retrievevars(322,0)
The above example will
retrieve a copy of variables previously stored under the ID 322 and overwrite the
current variable set. It will then delete the stored variable set under ID
322.
