ph_run PowerHome formula function
Execute a program
ph_run ( filespec )
| Argument | Description |
| filespec |
String representing the full path and filename of the program to be executed. Command line parameters can be included within this string. |
Integer. Returns a 1 if successful and –1 if an error occurs.
• ph_run("C:\powerhome\findMyPhone.exe 192.168.1.92 C:/powerhome/findMyPhone.txt")
• ph_run("C:\powerhome\jsonBI.exe login http://192.168.1.90:1002/json login password; camconfig pause ThtrCam -1") { Includes Command LIne Parameters (from the "/" on) }
