ph_runasuser PowerHome formula function
Executes an application as a specific
user.
ph_runasuser ( domain, user, pass, appl,
currdir, vis, async,
wait
| domain |
String. The domain of the userid you're attempting to run
as. Typically you would enter an empty string unless you're trying to
authenticate over a corporate network. |
| user |
String. The userid to run the program as. |
| pass |
String. The password for the userid. |
| appl |
String. The full path and filename of the application to
execute. |
| currdir |
String. The default directory you wish the application to
start from. |
| vis |
Integer. Whether the application should be visible or not.
Use 0 for the app to run in the background without a visible window. Use 1
to run the application normally. |
| async |
Integer. Whether the application runs asynchronously or not.
Use 0 to run the app synchronously and have PowerHome wait until the app
completes or the wait parameter is exceeded. Use 1 to have the app run
asynchronously and return control immediately to PowerHome. |
wait
Long. The time in milliseconds to wait
for an app that is run synchronously (async parameter is 0) to complete.
If the app is not done within the specified time, the function will
return. Use a negative value in order to
wait indefinitely.
Long. Returns the status of
the operation or the exit code from the application. - 1 is returned if PowerHome
cannot launch the application as the specified user. If the async parameter = 1
and the application was successfully launched, then 0 will be returned. If the
async parameter = 0 and the application is still running when the wait parameter
expires, then 259 will be returned signifying that the application is still
running. If the application completes before the wait parameter expires, then
the return value will be the exit code returned by
the application.
Use this function (or the ph_runasuser1
function) to execute an application as a specific user. Both the
ph_runasuser and ph_runasuser1 functions do the same thing but each uses a
different mechanism. Depending upon the system, one function or the other may
have better results. The ph_runasuser function uses CreateProcessWithLogon while the ph_runasuser1 function
uses CreateProcessAsUser .
ph_runasuser("","administrator","adminpass","regsvr32.exe
phuirt.dll","c:\powerhome",1,0,5000)
