ph_runscript_0 PowerHome formula function
Executes a WSH (Windows Script Host) file.
ph_runscript_0 ( timeout, filespec, name )
| Argument | Description |
| timeout |
Integer. Timeout. Specifies the time in milliseconds after which the user will be presented with an option to continue or discontinue execution of the script. A value of –1 means the script will never timeout. A value of 0 will fire the timeout event when it is detected that the script is hung. |
| filespec |
String. The full path and filename of the WSH file you wish to execute. |
| name |
String. The function or subroutine which should be executed. |
String. Returns the output of the called function or the text of an error.
• ph_runscript_0(0,"C:\powerhome\web\WthrImgs\weather.vbs","main")
