ph_runscript_2 PowerHome formula function
Executes a WSH (Windows Script Host) file and passes two parameters.
ph_runscript_2 ( timeout, filespec, name, parameter1, parameter2 )
| timeout |
Integer. Timeout. Specifies the time in milliseconds after which the user will be presented with an option to continue or discontinue execution of the script. A value of –1 means the script will never timeout. A value of 0 will fire the timeout event when it is detected that the script is hung.
| filespec |
String. The full path and filename of the WSH file you wish to execute.
| name |
String. The function or subroutine which should be executed.
parameter1
Value. The first parameter to be passed to the called function. Can be any datatype.
parameter2
Value. The second parameter to be passed to the called function. Can be any datatype.
String. Returns the output of the called function or the text of an error.
• ph_runscript_1(10,"C:\powerhome\web\WthrImgs\weather.vbs","main","temperature","Fahrenheit")
• ph_runscript_1(0,"C:\powerhome\Control\ContactSense.vbs","main","Input",2)
