ph_runsync PowerHome formula function
Launches an external executable and waits for it to complete.
ph_runsync ( path, wait, waittype )
path
String. The full path and filename of the executable to run.
wait
Long. The number of milliseconds to wait for the executable to complete. Use -1 to wait indefinately.
waittype
Integer. The type of waiting for
PowerHome
to perform. If 0, then PowerHome will not be locked and other functions may be performed (however, the execution queue will not process any more actions until this function completes). Any other value and PowerHome will be frozen and appear to be hung until the application completes or times out.
Integer. 0 is returned if the function returns because the executable was closed. 1 is returned if the function returns because the timeout (wait) parameter was exceeded.
