ph_runsync1 PowerHome formula function
Execute
an application synchronously or
asynchronously.
ph_runsync1 ( path, currdir, async,
wait
| path |
String. The full path and filename of
the executable to run. |
| currdir |
String. The default directory for the program to be executed
in. |
| async |
Integer. Determines whether the application will run
asynchronously or synchronously. Use 0 for synchronous execution. Use 1
for asynchronous execution. |
| wait |
Long. The number of milliseconds to
wait for the executable to complete if
the async parameter is 0. Use - 1 to wait indefinately. |
Long. If the async parameter is 1, then 0
will be returned immediately. If the async parameter is 0 and the
application is still running when the wait parameter expires, then 259 will be
returned signifying that the application is still running. If the application completes before the wait parameter expires, then the
return value will be the exit code returned by
the application.
Use this function to execute an application
under the PowerHome users context either asynchronously or synchronously. If you
need to execute an application using a different user context, use the
ph_runasuser or ph_runasuser1 functions.
ph_runsync1("notepad.exe","",1,0)
The
above example will execute the Windows notepad application and return control
immediately back to PowerHome (run asynchronously).
