ph_saveurl1 PowerHome formula function
Retrieves the resulting HTML / data from the specified URL. and saves the results to a file
ph_saveurl1 ( as_url, as_file, ai_writemode, ai_type, al_timeout )
ph_saveurl1 ( as_url, as_headers, as_file, ai_writemode, ai_type, al_timeout )
| Argument | Description |
| as_url | String. The URL whose HTML / data you wish to save to a file |
| as_headers | String (Optional). Additional HTTP headers you would like to be sent as part of the request. Specify headers in the same format that would be used for structuring a valid HTTP request. Separate multiple headers with either a carriage return / linefeed pair or a
linefeed (use the same separator for ALL the headers). An example header may look like: "Accept-Type: text/html~r~nPragma: no-cache". If this parameter is omitted, an empty string "" will be used |
| as_file | String. The full path and filename that you wish to save the results of the URL to |
| ai_writemode | Integer. Specifies how to save the data to the file. A value of 0 will append the data if the file already exists. Any other value will overwrite the file if it already exists |
| ai_type | Integer. A number representing the method of HTML retrieval from the URL. See usage below for an explanation of the valid types |
| al_timeout | Long. The max length of time in either seconds or milliseconds (dependent upon the ai_type value) to wait for the HTML return before the function times out |
String. Returns either the HTTP
headers from the URL request or an
error message. Various errors may be encountered depending upon the method
used to retrieve the HTML specified by the ai_type parameter. If an
error occurs, the return value will start with "*ERROR* - " followed by a description of the error
This function is an upgraded and expanded
version of the original ph_saveurl function.
The following table details the valid
values for the ai_type parameter:
| 0 |
A type of 0 will cause the HTML to be retrieved via a raw socket (this is the same as
the ph_saveurl function). The HTTP request is constructed internally and then sent
via a raw socket. The al_timeout parameter is in seconds |
| 1 |
A type of 1 will retrieve the HTML using a Catalyst HTTP control. The al_timeout parameter is
in seconds |
| 2 |
A type of 2 will also retrieve the HTML using a Catalyst HTTP control but does so using
slightly different methods than type 1 in case one or the other has
compatibility problems. The al_timeout parameter is in seconds |
| 3 |
A type of 3 will also retrieve the HTML using a Catalyst
HTTP control but does so using a different method than type 1 or
type 2. The al_timeout parameter is in seconds |
| 4 |
Returns "*ERROR* - Not supported" |
| 5 |
Retrieves the HTML using an
"msxml2.xmlhttp" control. The al_timeout parameter is in milliseconds |
| 6 |
"msxml2.serverxmlhttp" control. The al_timeout parameter is in milliseconds |
| 7 |
"winhttp.winhttprequest" control. The al_timeout parameter is in milliseconds |
| 8 |
Retrieves the HTML using a C#
WebRequest object. The al_timeout parameter is in milliseconds |
| 9 |
HttpWebRequest object. The al_timeout parameter is in milliseconds |
| 10 |
WebClient object with the DownloadString function. The al_timeout parameter is not relevant since
this method does not allow specifying a timeout |
| 11 |
| 12 |
Retrieves the HTML using a C# WebClient object with
the DownloadString function. The C# WebClient object has been extended such that it supports
timeout values. The al_timeout parameter is in milliseconds |
| 13 |
Any other value
Any other value will result in an empty string "" being returned
ph_saveurl1("https://www.power-home.com/images/ph.png","c:\powerhome\ph.png",1,8,5000)
The above example will retrieve the binary data for the
ph.png graphic file using a C# WebRequest object and save it
to the c:\powerhome directory. The function will timeout in 5 seconds (5000 millseconds) if
the result hasnt been returned by
then.
