ph_saveurlviaproxy1 PowerHome formula function
Retrieves the output from a URL using
the specified proxy server values and saves it to a file.
ph_saveurlviaproxy1 ( as_url, as_proxy, al_proxyport, as_authorization, as_file, ai_writemode, ai_type, ai_timeout )
ph_saveurlviaproxy1 ( as_url, as_headers, as_proxy, al_proxyport, as_authorization, as_file, ai_writemode, ai_type, ai_timeout )
| as_url |
String. The URL whose HTML you wish to retrieve |
| as_headers |
String (Optional). Additional HTTP headers you
would like to be sent as part of the request. Specify headers in the same
format that would be used for structuring a valid HTTP request. Separate
multiple headers with either a carriage return / linefeed pair or a
linefeed (use the same separator for ALL the headers). An example header
may look like: "Accept-Type: text/html~r~nPragma: no-cache". If this
parameter is omitted, an empty string "" will be used |
| as_proxy |
String. The proxy server the request
will made through |
| al_proxyport |
Long. The proxy server
port |
| as_authorization |
String. The userid and password for the
proxy server. Separate the userid from the password using a colon
character. Example: userid:password |
| as_file |
String. The full path and filename to save the URL output
to |
| ai_writemode |
Integer. Controls how the data is saved.
Use 0 to append the output to the file. Use 1 to replace the file if it currently exists |
| ai_type |
Integer. A number representing the
method of HTML retrieval from the URL. See usage below for an explanation
of the valid types |
| ai_timeouot |
Integer. The max length of time in
seconds to wait for the HTML before the function times out
String. Returns either the HTTP headers from the URL or an
error message
Use this function to retrieve the output
from a URL via a proxy server and directly save it to a file. This will allow
you to retrieve binary data that isnt possible to retrieve using the ph_geturl
functions.
See the table below
for an explanation of options available to the type parameter:
| 0 |
Retrieves the URL output using a raw
socket. This would be identical to the method used by the ph_saveurlviaproxy
function. |
| 1 |
Catalyst HTTP control using method 1. |
| 2 |
Catalyst HTTP control using method 2. |
| 3 |
Catalyst HTTP control using method 3. |
Multiple
methods are provided as certain websites, operating systems, etc. may have a
problem with one method or the other. Choose the method that produces the most
desireable results.
ph_saveurlviaproxy1("www.power-home.com/images/phwiki.gif","192.168.0.150",80,"userid:password","c:\powerhome\phwiki.gif",1,1,5)
