ph_secondsdiff PowerHome formula function
Returns the number of seconds one time occurs after another.
ph_secondsdiff ( time1, time2 )
time1
A time value that is the start time of the interval being measured
time2
A time value that is the end time of the interval
Double. Returns the number of seconds time2 occurs after time1. This function always assumes that time2 occurs after time1. If time1 is 23:59:59 and time2 is 00:00:01 then the returned value will be 2 even though time2 is less than time1. Partial seconds are returned in decimal format.
