ph_sendsmtpemailfile1 PowerHome formula function
Sends email (and optionally files) using SMTP
via a C#
SmtpClient control
ph_sendsmtpemailfile1 ( as_server, al_port, as_user, as_password, ai_usessl, as_from, as_to, as_subject, as_message, as_attachments )
| Argument | Description |
| as_server | String. The IP or URL of the SMTP server to use |
| al_port | Long. The port for the SMTP server. Typically
this is 25 |
| as_user | String. The username to send SMTP email as for the server |
| as_password | String. The password for the above username.
Supply an empty string "" if username/password is not required |
| ai_usessl | Integer. A flag to specify whether to use
SSL/TLS or not. Use 0 to NOT enable SSL/TLS. Any other value to enable it |
| as_from | String. The "from" email address |
| as_to | String. The "to" email address |
| as_subject | String. The subject for the email |
| as_message | String. The email message body |
| as_attachments | String. The full path and filename of files to
attach to the email. Separate multiple files with a vertical bar "|"
character. Set this parameter to an empty string "" if there are no file attachments |
Integer. Returns 0 if successful.
Returns 1 if
an exception occurs
Use this function as an alternative to the
ph_sendsmtpemail( ) and ph_sendsmtpemailfile( ) functions (both of which use a
Catalyst SMTP control). Depending upon the particular SMTP server one function
over the other may
perform better
• ph_sendsmtpemailfile1("smtp.gmail.com",465,"dhoward@gmail.com","yourpassword",1,"dhoward@gmail.com","support@power-home.com","Problem
with controller","An error occurred at 2020-05-17 18:10 with the Insteon
controller","c:\powerhome\screenshot1.jpg|c:\powerhome\screenshot2.jpg") -
Returns 1 if successful. NOTE: Google has recently updated their service and by
default no longer allows what they deem "less secure apps" to send SMTP unless
youturn on "allow less secure apps" in your GMail settings. Even though this
example uses SSL and follows GMail guidelines, "allow less secure apps" must be
enabled in order for the example to
work
• ph_sendsmtpemailfile1()
