ph_sendsmtpemailfileasync PowerHome formula
function
Sends email via SMTP asynchronously with the
option to automatically perform a PowerHome action once the email is sent. This
function also allows for file attachments to be sent.
ph_sendsmtpemailfileasync ( type, id,
server, port, from, to, subject, message, attach )
| type |
Integer. The type of PowerHome action
you'd like executed when the email is sent. Use 0 to not trigger any
action. Use 1 to trigger a macro. Use 2 to execute a named formula ID. Use
3 to execute a raw formula. This parameter goes hand in hand with the id
parameter. |
| id |
String. Data for the triggered action.
If type is 0, then set this parameter to an empty string. If type is 1,
then set ID to a valid macro ID. If type is 2, then set ID to a valid
formula ID. If type is 3, then ID should contain a valid raw formula you'd
like to be executed. |
| server |
String. The IP or URL of the SMTP
server. |
| port |
Long. The port for the SMTP server.
Typically, this will be 25. |
| from |
String. An email address for who the
mail is from. If your SMTP server requires authentication then this field
will also contain the userid and password. See usage below for more
detail. |
| to |
String. The email address to send the
email to. If you're sending to multiple recipients, then separate the
email addresses with a comma. |
| subject |
String. The subject of the email.
| message |
String. The message body of the email. |
attach |
String. The full path and filename of
the file attachment you'd like to send. Separate multiple attachments with
a vertical bar character "|". Don't use spaces. |
Integer. This function will return a 0.
Use this function to send email with
attachments via SMTP asynchronously. Email will be sent in the background and
PowerHome will operate without hanging for the email to complete. If you'd like
to trigger an action once the email is sent, set the type and id parameters
appropriately.
If you trigger a
process (type = 1, 2, 3) when the email is sent, then your macro or formula will
have access to the results of the SMTP email send operation. Three return values
are available. Use ph_getmtret to retrieve the results of the send process. If
successful, this value will be 0. If a failure occured, this value will be a
positive number from 1 to 9 indicating at what step in the send process the
failure occured. Use ph_getlasterror to retrieve a numeric value indicating what
the specific error was. This value will be 0 if there is no failure, otherwise
non-zero if a failure occured. Use ph_getlasterrorstring to retrieve a string
representation of what step in the send process a failure occured. If email
transmission was successful, then this string will indicate success.
authentication, then embed the credentials in the from parameter. The from
parameter should first contain the from email address followed by a comma (don't
use any spaces) followed by the SMTP userid followed by a comma followed by the
SMTP password.
ph_sendsmtpemailfileasync(1,"EMAILCOMPLETE","www.smtpserver.com",25,"power-home.com,ph,mypass","dhoward@myx10.com","Test
Message","This is a test message
body","c:\powerhome\phwiki.gif|c:\powerhome\pwrhome.ini")
The above example will send email asynchronously along with
the two specified attachments and when complete, will execute the EMAILCOMPLETE
macro.
