ph_setanalogdisplay PowerHome formula function
Sets the display values associated with records in the analogio table (Analog I/O screen) that will display in the Device Status screen
ph_setanalogdisplay ( al_foreground, al_background, as_graphic, ai_refresh )
ph_setanalogdisplay ( as_id, al_foreground, al_background, as_graphic, ai_refresh )
as_id
String (Optional). The ID of the record in the analogio table. If this parameter is omitted
the system variable ANALOG will be used for the ID
al_foreground
Long. The foreground color to display in the Control area of the Device Status screen. Use a negative number to use the existing value
al_background
Long. The background color to display in the Control area of the Device Status screen. Use a negative number to use the existing value
as_graphic
String. The path and filename of a graphic to display in the Control area of the Device Status screen. Use a string containing a single space " " to use the existing value
ai_refresh
Integer. Use 0 to update the table but not refresh the Device Status screen if open. Any other value will update the table as well as refresh the open Device Status screen
Integer. Returns 0 if successful. Returns 1 if the ID does not exist. Returns 2 if the analogio table cannot be updated
Since the Analog I/O screen only contains a
single setting for foreground, background, and graphic, this function allows the user flexibility in changing these static values based upon the current value of the particular Analog I/O point. This function may be called in the CalctoRaw and RawtoCalc formulas defined for the Analog I/O point. If called from within the CalctoRaw or RawtoCalc formulas, you can use the syntax that omits the as_id parameter
• ph_setanalogdisplay("KITCHENLIGHT",
-1,rgb(255,255,0)," ",1) - Sets the background color for the
KITCHENLIGHT Analog I/O device to yellow. The foreground color and graphic
is unchanged. The Device Status screen is refreshed to show the
changes.
