ph_setccobj PowerHome formula function
Changes the attributes of a Control Center object. You can change all the attributes at once or individual ones depending upon the values you pass
ph_setccobj ( as_text, ai_x, ai_y, ai_width, ai_height, al_fcolor, al_bcolor, ai_border )
ph_setccobj ( as_tab, as_id, as_text, ai_x, ai_y, ai_width, ai_height, al_fcolor, al_bcolor, ai_border )
as_tab
String (Optional). The ID of the Control
Center tab containing the button. If this parameter is omitted, system variable CCTAB will be used
as_id
String (Optional). The ID of the object on the
specified CC tab. If this parameter is omitted, system variable CCOBJ will be used
as_text
String. The text to place on the object. Use "" (empty string) to remove the text. Use a single space " " to not change the text
ai_x
Integer . The x position of the object. This is the horizontal position of the upper left corner of the object. Use -1 to not change the x position
ai_y
Integer . The y position of the object. This is the vertical position of the upper left corner of the object. Use -1 to not change the y position
ai_width
Integer . The width of the object. Use -1 to not change the width
ai_height
Integer . The height of the object. Use -1 to not change the height
al_fcolor
Long. The foreground color of the object. Use -1 to not change the foreground color
al_bcolor
Long. The background color of the object. Use -1 to not change the background color
ai_border
Integer. The border of the object. 0 = No border, 2 = Box, 5 = lowered, 6 = raised, and 10 = button. Use -1 to not change the border
Integer. Returns 0
Use this function or the individual ph_setcc functions to change the appearance of Control Center objects on the fly. Using this technique, you can make Control Center objects reflect the state of items. Any changes made to the Control Center in this manner are NOT permanent. These changes will be seen in the desktop Control Center as well as the web version of the Control Center.
• ph_setccobj("MAIN","FAMRMLIGHT","On,
100%", -1, -1, -1, -1, 0,rgb(255,255,0), -1) - On Control Center tab
MAIN, object FAMRMLIGHT, the displayed text is updated to "On, 100%", the
foreground color is set to black, and the background color is set to yellow.
Other attributes are
unchanged
