ph_setccobjfcolor PowerHome formula function
Updates the foreground color for the specified Control Center object
ph_setccobjfcolor ( al_color )
ph_setccobjfcolor ( as_tab, as_id, al_color )
as_tab
String (Optional). The ID of the Control Center tab containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the object on the specified tab. If this parameter is omitted, the system variable CCOBJ will be used
al_color
Long. The RGB color value you would like to set to the foreground color for the object
Long. Returns 0
Use this function to set the
foreground color for a Control Center object on a CC tab. A typical use of this
function would be to set the current foreground color of a Control Center object
that was triggered and initiated an action such as a formula or macro. In that
use case scenario, you can call the function without parameters and
the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to set the foreground color for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_setccobjfcolor(rgb(255,255,255)) - If called from
within a formula that was triggered by the action of a Control Center object,
sets the foreground color for that CC object
to white
• ph_setccobjfcolor("TV","POWER",0) - Sets the
foreground color for the POWER object on the TV Control Center
tab to black
