ph_setccobjwidth PowerHome formula function
Sets the width for the specified Control Center object
ph_setccobjwidth ( ai_width )
ph_setccobjwidth ( as_tab, as_id, ai_width )
as_tab
String (Optional). The ID of the Control Center tab containing the object. If this parameter is omitted, the system variable CCTAB will be used
as_id
String (Optional). The ID of the Control Center object on the specified tab. If this parameter is omitted, the system variable CCOBJ will be used
ai_width
Integer . The width value to set the specified CC object to
Long. Returns 0
Use this function to set
the width for a Control Center object on a CC tab. A typical use of this
function would be to set the current width of a Control Center
object that was triggered and initiated an action such as a formula or macro. In
that use case scenario, you can call the function without parameters
and the ID's for both the tab and object will be automatically supplied by the system variables. If you wish to set the width for a CC object other than one that initiated an action, you must specify both the tab and object ID's
• ph_setccobjwidth("TV","POWER",200)
- Sets
the width for the POWER object on the TV tab to
200
