Integer. Returns 1 if the filter succeeds. - 1 is returned if the sort fails.
Use the ph_setdevicesort formula to programatically sort the rows displayed on the Device Status Screen.
The sort criteria for a column has one of the forms shown in the following table, depending on whether you specify the column by name or number. Order is a, asc, or ascending for ascending order or d, desc, or descending for descending order. Order is case insensitive. If you omit order or specify an unrecognised string, the sort is performed in ascending order.
You can specify secondary sorting by specifying criteria for additional columns in the format string. Separate each column specification with a comma.
| Syntax for sort order |
Examples |
| columnname order |
"location a,key_desc a" |
"type" |
| #columnnumber order |
"#6 D,#7 A" |
