ph_setframe PowerHome formula function
Allows you to programmatically control the
state and size/position of the PowerHome main application
window.
ph_setframe ( state, x, y, width, height
| state |
Integer. Controls the state of the frame. Use 0 for normal.
Use 1 for minimized. Use 2 for maximized. |
| x |
Integer. The x position of the upper
left corner of the frame. Set this value to a negative number to not change the x
position. |
| y |
Integer. The y position of the upper
left corner of the frame. Set this value to a negative number to not change the y
position. |
| width |
Integer. The desired width of the
frame. Set this value to 0 or negative to not change the width. |
height
Integer. The desired height of the
the height.
Integer. Returns 0 if successful. Returns 1
if the state parm is 0 and the frame is currently in kiosk mode (see
ph_setmode function).
Returns 1 if PowerHome
is currently in kiosk mode and any of the x, y, width, or height parms are
not 0.
Use this function to control size,
position, and state of the main PowerHome application window.
ph_setframe (0,100,100,1200,1000)
The
above example will set the main PowerHome window to normal mode and position it
at 100,100 with dimensions of 1200
x
1000.
