ph_setlocals PowerHome formula function
Allows for the quick initialization of local variables [LOCAL1] thru [LOCAL5]
ph_setlocals ( local1, local2, local3, local4, local5 )
local1
Any. The value to assign to [LOCAL1]. Data can be of any standard type.
local2
Any. The value to assign to [LOCAL2]. Data can be of any standard type.
local3
Any. The value to assign to [LOCAL3]. Data can be of any standard type.
local4
Any. The value to assign to [LOCAL4]. Data can be of any standard type.
local5
Any. The value to assign to [LOCAL5]. Data can be of any standard type.
Integer. Returns 0.
Use this function to rapidly set the first
5 LOCAL variables. If you only want to set some of the LOCAL variables, supply a
string containing a single space for the variables you wish to leave unchanged.
ph_setlocals(35,"Test","
",2014-06-19,321.25)
The above example will set LOCAL1,
LOCAL2, LOCAL4, and LOCAL5 to the specified number, string, date, and decimal
respectively. LOCAL3 will not be changed since it is set to a single space.
