ph_setothercounter PowerHome formula (Deprecated)
function
This function will set a specific value
to a counter object within a controller
ph_setothercounter ( ctlr, counter,
value )
| ctlr |
String. The ID of the controller whose
counter you want to set. |
| counter |
Integer. The number of the counter within the specified
controller that you wish to set. |
| value |
Long. The actual value you'd like to
set the counter to. |
Integer. Returns the result of the
counter set operation. A 0 would indicate success. Any other value would be a
failure.
This function is currently only supported
by the Elk M1 Gold controller. Counter numbers can be from 1 to 64.
This function will cause the controller to set the specified counter to the
specified value.
ph_setothercounter("ELK",5,0)
