ph_setotherdigitalout PowerHome formula function (Deprecated)
Sets or clears a Digital Output
ph_setotherdigitalout ( controller, type, unit, point, status )
controller
The ID of the controller.
type
The type of the Digital point. Use 0 for Input and 1 for Output.
unit
The address of the unit.
point
The digital output point you wish to set or clear.
status
The status you wish to set. 1 will turn the relay on, 0 will turn the relay off
Integer. Returns a 0 if successful. - 1 is returned if the controller is not available, - 2 is returned if the controller does not support digital outputs, - 3 is returned if the unit is out of range, - 4 is returned if the point is out of range.
Currently only supported by the CPU-XA/Ocelot (with SECU-16, SECU-16I, or RLY-8 interface), the Velleman K8000 controller, and the Elk M1 Gold.
To use this function with the CPU-XA/Ocelot, specify the ID of the controller whose type is CPU-XA/Ocelot. The "unit" must be a number from 1 to 128 corresponding with the address of the SECU-16, SECU-16I, or RLY-8 whose digital output you wish to control. The "point" must be a number from 0 to 15 and corresponds to the specific point on the addressed SECU-16, SECU-16I, or RLY-8.
To use this function with the Velleman K8000, specify the ID of the controller whose type is K8000. The "unit" value must be 0. The "point" value must be a number from 1 to 64 and corresponds to the specific point whose digital output you wish to set or clear.
For use with the Elk M1 Gold, specify the ID of the Elk M1 controller. For the "Unit" and "Point" properties, the Elk M1 Gold supports two different numbering schemes. You can set the "unit" value to 0 and then set the "Point" value to the Elk logical point value. You can also set the "Unit" to the address of any external modules (use 0 for the on-board points) and the "Point" to the actual point value on the external board.
