ph_setothervar PowerHome formula function (Deprecated)
Sets the value of an internal variable on the specified controller.
ph_setothervar ( controller, var, value )
controller
The ID of the controller.
var
The number of the internal variable whose value you wish to set.
value
The value you wish to set the internal variable to.
Integer. Returns 0 if successful. - 1 is returned if the controller is not available, - 2 is returned if the controller does not support internal variables, - 3 is returned if the variable is out of range, - 4 is returned if the value is out of range.
Currently only supported by the CPU-XA/Ocelot controller. To use this function with the CPU-XA/Ocelot, specify the ID of the controller whose type is CPU-XA/Ocelot. The "var" must be a number from 0 to 127 corresponding to the internal variable of the CPU-XA/Ocelot you wish to set. The "value" must be in the range of 0 to 65535 for the CPU-XA/Ocelot.
