ph_setsysvol PowerHome formula function
Sets the system volume level.
ph_setsysvol ( n )
n
A long representing the system volume level. This value should be between the min and max values as returned by the ph_getsysvolmin and ph_getsysvolmax functions respectively.
Integer. Returns 0 if successful. Returns a negative value if an error occurs.
