ph_settemps PowerHome formula function
Allows for the quick initialization
of temp variables [TEMP1] thru [TEMP5]
ph_settemps ( temp1, temp2, temp3, temp4,
temp5 )
| temp1 |
Any. The value to assign to [TEMP1].
Data can be of any standard type. |
| temp2 |
Any. The value to assign to [TEMP2].
| temp3 |
Any. The value to assign to [TEMP3].
| temp4 |
Any. The value to assign to [TEMP4].
| temp5 |
Any. The value to assign to [TEMP5].
Integer.
Returns 0.
Use this function to rapidly set the first
5 TEMP variables. If you only want to set some of the TEMP variables, supply a
string containing a single space for the variables you wish to
leave unchanged.
ph_settemps(35,"Test","
",2014-06-19,321.25)
The above example will set TEMP1, TEMP2, TEMP4, and
TEMP5 to the specified number, string, date, and decimal respectively. TEMP3
will not be changed since it is set to a single
space.
