ph_setwebcookie PowerHome formula function
Sets a web cookie within the PowerHome web server.
ph_setwebcookie ( name, value, path, domain, expires )
name
String. The name of the cookie.
value
String. The value to assign to the cookie.
path
String. An optional path parameter for the cookie.
domain
String. An optional domain parameter for the cookie.
expires
Double. An optional parameter for setting the expiration of a cookie. The expiration date will be calculated using this parameter in minutes from the current time.
Integer. Returns 0.
This function only has meaning when run from within the context of a PowerHome PSP page.
