ph_snapxml PowerHome formula function
Retrieves element data within
an XML string identified by a sequence of 1 or more element names and a specified
instance number
ph_snapxml ( as_xml, as_key )
ph_snapxml ( as_xml, as_key, ai_instance )
| Argument | Description |
| as_xml | String. A string containing XML data whose element
data you would to extract |
| as_key | String. An XML element
name identifying the attribute. If you want to fully qualify a
heirarchy of elements, separate element names with a "<" character.
Only the rightmost element name will have its attribute retrieved |
| ai_instance | Integer (Optional). The matching instance
number you would like to retrieve. Use a value of 1 to retrieve the
first matching instance. If this parameter is omitted, a value of 1 will be implied |
String. Returns the data between the opening and closing tags of the tag specified in the as_key parameter. Returns
"*ERROR* - Could not locate key" if the specified element name sequence and instance could not be found
Use this function to extract specific attribute
values contained within
XML data
• ph_snapxml(ph_readfile("c:\powerhome\phdata.xml"),"row<temperature",3)
- Returns the string
of
data appearing between the 3rd instance of the opening and closing tags
of the specified key (temperature) contained in the c:\powerhome\phdata.xml file. The
search that
is performed must match the format
of <row>...<temperature>...</temperature>...</row>
