ph_sortdata PowerHome formula function
Sorts the data in a Data
Retrieval area
ph_sortdata ( ai_dsvar, as_sort )
| Argument | Description |
| ai_dsvar | Integer. The Data Retrieval area number you
wish to sort. Valid values are 1 thru 20 |
| as_sort | String. The sort description to be performed.
See Usage below |
Long. Returns 0 if successful. Returns
-1 if the ai_dsvar parameter is out of range (1 - 20). Returns -2 if the Data
Retrieval area is not initialized. Returns -3 if the specified sort is not
valid. Returns -4
if the sort fails.
Use this function sort previously
retrieved data in a Data Retrieval area
The as_sort parameter is a string containing 1 or more columns that you would like to sort by with the option of specifying either an ascending or descending sort. You can use either the column name or a column number. If you use a column number, prefix the number with the pound "#" sign. If you don't specify "a" (ascending) or "d" (descending) the default will be ascending. Sample sort strings are below:
"#1 a, #2 d"
"ddtype, dddisplay"
"address d"
• ph_sortdata(1,"#1 a, dddisplay d") -
Returns 0 if successful. Sorts Data Retrieval area 1 first by the 1st column
ascending and then by the column named "dddisplay"
descending
