ph_split PowerHome formula function
Splits a formatted string that consists of
smaller strings separated by a separator character and places the results into
local
variables.
ph_split ( data, sep, local
| data |
String. The data you would like split. |
| sep |
String. The separater character or string. |
local
Integer. The starting index of the
local variables to have the split strings
copied into.
Long. Returns the number of strings that
were split.
Use this function quickly break apart short
strings into individual data. Useful for parsing out data from comma
separated values.
ph_split("70.0,69.5,32.8,65.1,Windy",",",3)
The above
example will set [LOCAL3] to 70.0, [LOCAL4] to 69.5, [LOCAL5] to 32.8, [LOCAL6]
to 65.1, and [LOCAL7] to
Windy.
