ph_sql_n PowerHome formula function
Executes a SQL statement against the PowerHome database and returns the result as a numeric
ph_sql_n ( sql )
sql
String. A string containing the SQL select statement to run.
Double. Returns the result as a numeric value. The SQL may return multiple rows, but only data from the first row will be returned by the function. The SQL should only return a single column of data.
