ph_sqlselectinto PowerHome formula function
Executes a SQL query and returns the values of the first row into the appropriate LOCAL? system variables.
ph_sqlselectinto ( n, s )
n
The number of the starting LOCAL system variable to retrieve data into. This value must be between 1 and 10 inclusive. The first column of the SQL statement will be retrieved into the LOCAL system variable identified by n. Subsequent columns will be retrieved into subsequent LOCAL varaibles.
s
String representing a valid SQL statement. Multiple rows are allowed to be returned by the SQL select but only the first row as determined by the SQL order by will be returned.
Integer. Returns a 0 if successful. Returns 1 if n is outside of the range 1 to 10. Returns 2 if queries are against the REGINFO table. Returns 3 if the SQL is invalid. Returns 4 if an error occurs while creating the query.
Use this function to quickly retrieve data from the PowerHome database when you only need a single row of data. If you need to step thru multiple rows, use the ph_sqlselect function instead. If you declare a query that returns 3 columns and specify a value of 6 for n, then column 1 will go into LOCAL6, column 2 will go into LOCAL7, and column 3 will go into LOCAL8. If your query returns columns greater than what will fit into the LOCAL variables (LOCAL10 maximum), the extra columns will be discarded.
