ph_stacktrace PowerHome formula function
Returns a trace of the PowerHome execution stack
ph_stacktrace ( )
Argument Description
String. Returns a trace of the execution stack. Returns "*ERROR - Runtime Error" if a runtime error occurs. Returns "*ERROR - Stack Trace Failed" if the stack trace fails
Use this function for debugging purposes to analyze the sequence of function calls and events that have taken place.
• ph_stacktrace() Returns the following string assuming the function was executed from the PowerHome multi-editor and no other routines are currently on the stack:
ph_stacktrace Line: 7
uo_function.f_evalformula Line: 16
w_wshedit.f_executeph Line: 23
m_editor.m_executescript.+clicked Line: 14
