| Argument | Description |
| type | String. The type of system function you wish to interact with. Current valid value is "ws" for webserver. |
| parm1 | Long. Parm1 to be passed for the specific function. |
| parm2 | String. Parm2 to be passed for the specific function |
| local | Integer. The local variable that you want extended data to be returned in (1 thru 10). Use a value of 0 to discard this data. |
| type | parm1 | parm2 | local | Return value | Notes |
| ws | 0 | enable | 0 | 0 if successful -1 if the webserver is already enabled -2 if an error occurs |
Use to enable the webserver |
| ws | 0 | disable | 0 | 0 if successful -1 if the webserver is already disabled |
Use to disable the webserver |
| ws | 0 | status | 0 | 0 if the webserver is disabled 1 if the webserver is enabled |
Check the current status of the webserver |
| ws | 0 to only read count 1 to read and reset count |
getbadlogincnt | 0 | Returns the total count of bad login
attempts -1 if the webserver is not active |
Get and optionally reset the count of bad login attempts |
getblacklistcnt | 0 | Returns the total count of hits from
blacklisted IP's -1 if the webserver is not active |
Get and optionally reset the count of hits from blacklisted IP's |
gettrustedcnt | 0 | Returns the total count of hits from trusted IP's -1 if the webserver is not active |
Get and optionally reset the count of hits from trusted IP's |
getguestcnt | 0 | Returns the total count of hits using the guest
account -1 if the webserver is not active |
Get and optionally reset the count of hits from the guest account |
getmastercnt | 0 | Returns the total count of hits using the master
Get and optionally reset the count of hits from the master account |
getunauthcnt | 0 | Returns the total count of unauthorized hits -1 if the webserver is not active |
Get and optionally reset the count of unauthorized hits |
gethitcnt | 0 | Returns the total hit count of all access types -1 if the webserver is not active |
Get and optionally reset the total count of hits |
gethitovercnt | 0 | Returns the total overflows of the gethitcnt counter. -1 if the webserver is not active |
The gethitcnt value overflows and is reset to 0 at 4,200,000,000 and this counter is incremented by 1. |
| ws | 0 | clearcounts | 0 | 0 if successful -1 if the webserver is not active |
Clears all above counts |
| ws | 0 | getallcounts | 1 thru 10. The number of the LOCAL variable to return the counts in. | 0 if successful -1 if the webserver is not active |
Retrieves all the counts into a formatted string and returns it in the specified LOCAL variable. |
| userdata | 1 thru 5 for table userdata1 thru userdata5 | truncate | 0 | 0 if successful -1 if parm1 is out of range -2 if parm2 is out of range |
Truncates the specified userdata (1 - 5) table. Keep in mind a truncate will delete all existing data. Useful resetting the autoincrement count in the userdata2 thru userdata5 tables. |
