ph_texttojson PowerHome formula function
Converts a flattened JSON string back
into JSON
ph_texttojson ( as_text, as_segsep, as_valsep, ai_flags )
| Argument | Description |
| as_text | String. The flattened JSON string or other
properly formatted text data |
| as_segsep | String. The character that is used to separate
the JSON segments in the formatted text |
| as_valsep | String. The character that is used to separate
segments from the value in the formatted text |
| ai_flags | Integer. A flags parameter controlling how the conversion is to
be performed. See Usage below |
String. Returns the previously
flattened JSON or properly formatted text as
a JSON string
Use this function to create JSON data from
previously flattened JSON such as the
output from the ph_flattenjson( ) function or to create JSON from properly
formatted text. A sample of properly formatted text
appears below:
Lights.FamilyRoom.status=On
Lights.Kitchen.status=Off
Temperature.FamilyRoom=76.6
Doors.value[0]=5
Doors.value[1]=6
Doors.value[2]=8
The ai_flags parameter currently only supports values of
0 or 1. A value of 0 will NOT try to interpret JSON arrays in the formatted
data. A value of 1 will look for JSON arrays in the format of "[indice]"
appearing at the end of a JSON segment. In the example formatted text above, you
can see a properly formatted JSON array in the "Doors.value" segments.
• ph_texttojson("Lights.FamilyRoom.status=On~r~nLights.Kitchen.status=Off~r~nTemperature.FamilyRoom=76.6~r~nDoors.value[0]=5~r~nDoors.value[1]=6~r~nDoors.value[2]=8~r~n",".","=",1)
- Returns the following JSON data: {"Lights": {"FamilyRoom": {"status": "On"}, "Kitchen": {"status": "Off"}}, "Temperature": {"FamilyRoom": "76.6"}, "Doors": {"value": [ "5", "6", "8"]}} This example has the ai_flags parameter set to 1 so the Doors.value segment is converted to a JSON array. The next example is the same data with the ai_flags parameter = 0
• ph_texttojson("Lights.FamilyRoom.status=On~r~nLights.Kitchen.status=Off~r~nTemperature.FamilyRoom=76.6~r~nDoors.value[0]=5~r~nDoors.value[1]=6~r~nDoors.value[2]=8~r~n",".","=",0)
- Returns the following JSON data: {"Lights": {"FamilyRoom": {"status": "On"}, "Kitchen": {"status": "Off"}}, "Temperature": {"FamilyRoom": "76.6"}, "Doors": {"value[0]": "5", "value[1]": "6", "value[2]": "8"}}
