ph_traceoff PowerHome formula function
Terminates a currently active tracing session previously initiated with the ph_traceon( ) function
ph_traceoff ( )
Argument Description
Integer. Returns 0 if successful. Returns 1 if function fails
Use this function to terminate an active trace session that was previously initiated with the ph_traceon( ) function. The tracing and profiling functionality within PowerHome consists of three functions. The ph_traceon( ) function allows you to define and start a trace session. The ph_traceoff( ) function allows you to terminate a trace session. The ph_tracemsg( ) function allows the user to insert a user defined message into the trace file.
Tracing is not something a user would typically do on his own. The resulting trace file is not human readable and must be decoded by the developer using the PowerBuilder development environment in which PowerHome was written in. Tracing will usually be initiated at the developers request to help a user track down problems or issues they may be having
• ph_traceoff()
