ph_trim PowerHome formula function
Trims the specified string using the
specified trim
type.
ph_trim ( data, type, trim
| data |
String. The string you would to perform the trim operation
on. |
| type |
Integer. The type of trim operation to perform. See usage
below. |
trim
String. A set of characters that you
would like to have trimmed from the string. Use an empty string "" to trim
only spaces.
String. Returns the
trimmed string.
Use this function to perform trim
operations on a string. Most trim operations only remove space characters but by
specifiying a group of characters in the trim parameter, you can trim other
characters as well.
The valid values for the type parameter are detailed
below:
| 0 |
Performs a left trim. Characters will be removed from the
left |
| 1 |
Performs a right trim. Characters will be removed from the
right |
2
Performs both a left and right trim.
Characters will be removed from both the left and
the right.
ph_trim(" , | & This
is a test. & |",2," ,|&")
The above example will return "This is a
test."
