ph_ttsgetstatus PowerHome formula function
Returns the speaking status of the default TTS engine.
ph_ttsgetstatus ( )
Integer. Returns the speaking status of the default TTS engine. A value of 0 means that the default TTS engine is not speaking. A value of 1 means that the default TTS engine is either speaking or paused in speaking.
