ph_upbraw PowerHome formula function
Send raw UPB commands to a single UPB device.
ph_upbraw ( ctlr, nid, uid, chan, cmd, arg1, arg2 )
| ctlr |
String. The ID of the UPB controller to use. |
| nid |
Integer. The Network ID to send to. |
| uid |
Integer. The Unit ID to send to. |
| chan |
Integer. The channel to send to. |
| cmd |
Integer. The command to send. |
| arg1 |
Integer. Argument 1 for the command. |
| arg2 |
Integer. Argument 2 for the command. |
Integer. Returns a 0 if successful, -1 is returned if the controller is
not available, -2 is returned if the controller does not support UPB.
Use this funciton to send raw UPB commands to single UPB device. Valid
commands are 34 for Goto (arg1 is level, arg2 is ramp), 35 for Fade Start
(arg1 is level, arg2 is ramp), 36 for Fade Stop (arg1 and arg2 ignored),
37 for Blink (arg2 is blink rate), 38 for Indicate (arg1 is level, arg2
is ramp). You
can also use the enumerated values ugoto, ufadestart, ufadestop, ublink,
and uindicate.
