ph_upbrawlink PowerHome formula function
Send raw UPB commands to a group of linked UPB devices.
ph_upbrawlink ( ctlr, nid, lid, cmd, arg1, arg2 )
| ctlr |
String. The ID of the UPB controller to use. |
| nid |
Integer. The Network ID to send to. |
| lid |
Integer. The Link ID to send to. |
| cmd |
Integer. The command to send. |
| arg1 |
Integer. Argument 1 for the command. |
| arg2 |
Integer. Argument 2 for the command. |
Integer. Returns a 0 if successful, -1 is returned if the controller is
not available, -2 is returned if the controller does not support UPB.
Use this funciton to send raw UPB commands to group of linked UPB devices.
Valid commands are 32 for Activate Link (arg1 and arg2 are ignored), 33
for Deactivate Link (arg1 and arg2 are ignored), 34 for Goto (arg1 is
level, arg2 is ramp), 35 for Fade Start (arg1 is level, arg2 is ramp),
36 for Fade Stop (arg1 and arg2 ignored), 37 for Blink (arg2 is blink
rate), 38 for Indicate (arg1 is level, arg2 is ramp). You
can also use the enumerated values uactlink, udeactlink, ugoto, ufadestart,
ufadestop, ublink, and uindicate.
