ph_updatexml PowerHome formula function
Updates an attribute in an
XML string identified by a sequence of 1 or more element names and a specified
instance number
ph_updatexml
( as_xml, as_key, ai_instance, as_value )
| Argument | Description |
| as_xml | String. A string containing XML data whose
attribute you wish to update |
| as_key | String. An XML element
name identifying the attribute. If you want to fully qualify a
heirarchy of elements, separate element names with a "<" character.
Only the rightmost element name will have its attribute updated |
| ai_instance | Integer. The matching instance number you
would like to update. Use a value of 1 to update the first matching instance |
| as_value | String. The value to assign to the matching element attribute |
String. Returns the as_xml string with
the identified element attribute updated with the string in as_value. Returns
"*ERROR* - Could not locate key" if the specified element name sequence and
instance could
not be found
Use this function to update specific
attributes within
XML data
• ph_updatexml(ph_readfile("c:\powerhome\phdata.xml"),"row>temperature",3,"76.0")
- Returns the full string of XML that was contained in the
c:\powerhome\phdata.xml file with the 3rd instance of element names matching
<row>...<temperature>...</temperature>...</row>. The
value of the temperature element will be
"<temperature>76.0</temperature>"
