Use this function to retrieve information from an instance of Winamp running on the PowerHome computer. This function relies upon the data in the [Winamp] section of the pwrhome.ini file.
| Command |
| status |
Returns the current status of Winamp. Possible return values are "playing", "paused", "stopped", and "not running". |
| title |
Returns the title of the current song. |
| titlenum |
Returns the number of the current title within the current playlist. |
| version |
Returns the version of Winamp that is running. |
| trackpos |
Returns the current position in milliseconds of the current song. |
| tracklen |
Returns the length of the current song in seconds. |
| listlen |
Returns the length of the current playlist in tracks. |
| listpos |
Returns the current position within the playlist. |
| tracksamplerate |
Returns the sample rate of the current playing song. |
| trackbitrate |
Returns the bitrate of the current playing song. |
| tracknumchannels |
Returns the number of channels of the current playing song. |
| trackpercent |
Returns the percent complete of the current playing song. |
| shuffle |
Returns the status of the shuffle. |
| repeat |
Returns the status of the repeat. |
| listfilename |
Returns the filename of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listtitlename |
Returns the title name of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listpath |
Returns the path of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listartist |
Returns the artist of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listtitle |
Returns the title of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listalbum |
Returns the album of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listyear |
Returns the year of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listbitrate |
Returns the bitrate of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
| listlength |
Returns the length of a song within the playlist. The data parameter is the number of the song whose data you wish returned. Use - 1 for the current playing song. |
