ph_writefile PowerHome formula function
Writes data to the specified file
ph_writefile ( as_filename, ai_writemode, as_data )
ph_writefile ( as_filename, ai_writemode, as_data, ai_type )
| Argument | Description |
| as_filename | String. A string representing the path and filename of the file you wish to write to |
| ai_writemode | Integer. An integer representing how you wish to write to the file. A value of 0 will append the data to the file, any other value will cause the file to be overwritten |
| as_data | String. A string representing the data you wish to write to the file |
| ai_type | Integer (Optional). Specified the type of data
that is contained within as_data. If 0, the data is assumed to be standard
string data and will be written to the file as is. Any other value means
that as_data contains a hex encoded string that will first be decoded and
then the results will be written to the specified file. If this parameter
is omitted, a value of 0 is assumed |
Integer. Returns a 0 if successful. Returns a 1 if an error occurred while opening the file
Use this function to write data to a
file. If the file does not exist, it will first be created. You can write binary
data to a file by representing it as a hex encoded string and using an ai_type
value other
than 0
• ph_writefile("c:\powerhome\logs\log.txt",0,string(datetime(today(),now()))
+ ":" + ph_getvar_s(1,1) + "~r~n") - Appends the current date and time
along with the data contained in [LOCAL1] to the c:\powerhome\logs\log.txt
file
• ph_writefile("c:\powerhome\test.txt",1,"54455354",1)
- Overwrites or creates the file c:\powerhome\test.txt and writes the string
TEST to the
file
