ph_x10lookup PowerHome formula function
Returns the X10 device ID when given the housecode and unitcode.
ph_x10lookup ( hc, uc )
hc
String. The housecode to lookup.
uc
Integer. The unitcode to lookup.
String. Returns the X10 device ID from the X10 Devices table. Returns an empty string if the housecode/unitcode combination is not found.
