ph_x10other PowerHome formula function
This function is used to send non-standard
X10 commands via the specified
controller.
ph_x10other ( ctlr, house, cmd
| ctlr |
String. The ID of the controller to send the X10 command
to. |
| house |
String. The housecode for the X10 command. |
cmd
String. The X10 command
to send.
Integer. Returns - 1 if an error occurs
(such as the controller does not exist or the controller does not support X10
other commands). Otherwise, 0
is returned.
This function is currently only supported
by the CM15A RF controller. This function is for sending the non-standard X10
commands to this controller such as camera control commands. See the ActiveHome
Scripting SDK for a complete list of
valid commands.
ph_x10other("CM15ARF","K","CamGoPosition5")
The above
example tells the X10 camera on housecode K to go to preset position
5.
