ph_yamltojson PowerHome formula function
Converts YAML data into an equivalent
JSON string
ph_yamltojson ( as_yaml )
| Argument | Description |
| as_yaml | String. A string containing the YAML data you
wish to convert to JSON |
String. Returns a JSON string after
conversion from YAML. Returns "*ERROR* - " followed a description of the error
if
an exception occurs
Use this function to convert YAML data to
equivalent JSON data. This functions uses YamlDotNet and Newtonsoft.Json to
perform
the conversion
• ph_yamltojson(ph_readfile("c:\powerhome\phdata.yml"))
- Returns the YAML data in c:\powerhome\phdata.yml converted into an
equivalent JSON string. Returns "*ERROR* - " followed by an error description if
the data in the file is not properly formatted
YAML
