righta PowerHome formula function
Obtains a specified number of bytes from the end of a string.
righta ( string, n )
string
The string from which you want bytes returned
n
A long whose value is the number of bytes you want returned from the right end of string
String. Returns the rightmost n bytes in string if it succeeds and the empty string ("") if an error occurs.
If n is greater than or equal to the length of the string, Right returns the entire string. It does not add spaces to make the return value's length equal to n.
The following examples demonstrate typical syntax/ usage for this function.
• righta("[LOCAL1]",10) --> get the last 10 bytes from the string.
• if( righta( "[LOCAL1]", 12 ) = "HTTP/1.1 404", "ERROR", "Nextline") --> Return "ERROR" if the last 12 bytes indicate an HTTP error.
