setprofilestring PowerHome formula function
Creates or modifies a value within an INI file.
setprofilestring ( filename, section, key, value )
filename
A string containing the full path and filename of the INI file. If you don't include the full path, then PowerHome searches the path for filename.
section
A string containing the section to modify. If section does not exist, PowerHome will create it.
key
A string containing the key within a section to modify. If key does not exist, PowerHome will create it.
value
A string containing the value you wish assigned to the key.
Integer. Returns 1 if successful and - 1 if the filename cannot be found or accessed.
