Insteon Explorer - KPL Config
KPL Config
This screen allows you to configure the KeyPadLincs (KPL's) in your
Insteon network. To read the current settings of a KPL, double-click the
desired KPL from the list below. You may set the local level and ramprate
as well as the X10 address. You can also set the KPL to be either 6 or 8
button mode as well as the intra-button linking and toggle versus
non-toggle buttons.
When a KPL is in 6 button mode, it effectively has a total of 5 groups (1,
3, 4, 5, and 6). The wide top and bottom buttons are group 1 with the top
button being a non-toggle on and the bottom being a non-toggle off. In 8
button mode, the KPL has 8 groups from 1 to 8 with each button defaulting
to a toggle on/off button. Group 1 is always the local load.
When in 6 button mode, buttons 3, 4, 5, and 6 can be set to either toggle,
non-toggle on, or non-toggle off. When in 8 button mode, all 8 buttons can
be set the same as 6 button mode's 3 thru 6.
You may configure buttons other than group 1 to control the local load but
the current versions of KPL's do not allow any dim level other than what
was last used so you cannot setup a KPL to have a button control the local
load with 25%, 50%, 75%, and 100% settings. For this type of
functionality, it would be recommended to have the desired load controlled
by either an InlineLinc or SwitchLinc and then have the KPL send group
commands to the device controlling the load.
To set buttons as toggle, non-toggle on, and non-toggle off: The current
versions of KPL's have a flaw where the current status of a button as
non-toggle on or non-toggle off cannot be determined. All that can be
known is that the button is either toggle or non-toggle. This same flaw
also prevents us from setting in software whether the button will be
non-toggle on or non-toggle off. All we can do is set a button as toggle
or non-toggle. To set a button as non-toggle on or non-toggle off, first
start with the buttons as standard toggle buttons. Then go to the KPL and
manually press the buttons until the buttons you wish to set as non-toggle
on are lit and the buttons you wish to set as non-toggle off are not lit.
Go back to this util and then set the appropriate buttons from toggle to
either non-toggle on or non-toggle off. It doesnt matter (other than the
button is not set to be toggle) as the button will be set as non-toggle on
or non-toggle off based upon the current status of the button's lights.
To setup intrabutton linking: Intra-button linking allows you to set a
KPL's buttons to control one another. Keep in mind that intra-button
linking in no way trigger's the group controlled by a button and ONLY
controls the status of the button's light. If you wish to have a secondary
button (a button other than group 1) control the main button (group 1),
then you must do both intra-button linking as well as create a link with
the secondary button as a controller and the main button as a responder.
To control the lights of secondary buttons from other secondary buttons or
the main button, you only need to do intra-button linking. Placing a check
in the "LED On" box will cause the light of the button to track the light
of the controlling button. For example: If you place a check in LED On
boxes 3 and 4 of button 5, then when button 5 is on, both button 3 and 4
will be on. When button 5 is off, both button 3 and 4 will be off. By
placing a check in the "LED Off" box, the checked buttons will be off when
the controlling button is on. In the preceding example, if the checks are
in LED Off of 3 and 4 of the Button 5 group, then when button 5 is turned
on, buttons 3 and 4 will turn off if they were on. Turning button 5 off,
will not have an effect on buttons 3 and 4. Numerous combinations can be
obtained by checking the various LED On and LED Off boxes of the button
groups and experimentation will likely be necessary to achieve desired
results.
